AC removal
    thats what I figured. So then I should be worried about the check engine light blinking?
    *edit*
    nm, just shorted the two pins the lights are off.
    original E30 M3ís main purpose in life was to
    got the job done."
      *edit*
      I'm glad you got the light to go off by shorting the pins.
      Just so you know in the future, the e30 M3 does not have a "check engine" light. The "check" light that flashes in the instrument cluster is only there to let you know that one of the lights in the "check panel" above the rear view mirror has become lit. Once you push the check button on the check panel, the light in the instrument cluster stops flashing, but the light on the check panel will remain lit as long as the fault condition exists.
      Dominic
        Thanks again dominic.
        got the job done."
          Glad to help!
          Dominic
