So I'm to the final stage of my A/n instal, and now I have run into what seems to be my final problem.
The MAXX software recognizes the TPS, but it only allows me to get to 38% at the "low" end with throttles closed, and up to like 48% on the high end with throttles open.
Also, the Pententioner won't adjust. It says it needs to be rotated left, but no luck when I rotate the TPS said direction - is there something that I'm not grasping with that?
I bought this kit used off of a board member, and since have had to replace (actually, purchase) an air temp sensor, and now I fear that I'm going to be out the money again for a TPS. DON'T BUY USED! Now I understand why the person sold this particular setup.
I'm pretty confident that I wired things correctly given that the laptop is recognizing some TPS activity.... that's why I think the problem is in the unit itself. Please help!
Cheers,
Ted
Cheers,
Ted
