Dead tach and temp gauge.......
  • Dead tach and temp gauge.......
    After replacing the head on the car the tach and temp gauge quit working. I
    replaced the coolant sensors during the process. A hint from John on another
    board noted that if the reverse light wires were shorted out this would
    cause such a gremlin. Pulled the shifter boot off, unplugged the connector
    and sure enough the car side (not switch side) was shorted out together?
    Went to the back of the car, removed the light bulbs and the short goes
    away? Cool I though, the tach and temp gauge should work now.....nope.
    Pulled out the ETM and started tracking it. Found that pin #7 of C2 on the
    back of the instrument cluster is the tach input. I put the DVM on this wire
    and can see the pulsing input so I assume that the signal is reaching this
    far.
    Where do I go from here?
    Tony
    Check for blown fuse. This was the case for me since I always overlook the easy stuff.
      The fuses are all good.
        my tach isn't working and i think it may be the s.i. board.
          The batteries were dead. Went to RadShack and got some 700mah NiCad AA's and all is good. I guess having the battery unhooked for more than two weeks killed them.
            I've got the same problem after changing my interior carpet with instruments unplugged for 2 weeks. Sometimes coolant guage works but tach always does not work. Interestingly, the oil temp guage works. Is it difficult to change the ni-cad batteries? I checked my fuses (they are OK). Any other suggestions???
            TIA
            Joe
            1995 Porsche 993
            2001 BMW 530iA Sport (hers)
            2004 Ford F-150 FX4
            Gone:
            1985 BMW M635CSI
            2001 BMW M3
              One more thing: two of the red inspection lights stay on even after I turn the car off. What does that mean??
              1995 Porsche 993
              2004 Ford F-150 FX4
              Gone:
              1985 BMW M635CSI
              2001 BMW M3
                The oil temp gauge works on it's own circuit while the Tach and Coolant gauge are run through the SI board. BTW, there should be 5 green, 1 yellow and 1 red LED on all E30's 86-on including all M3's, yet you say you have 2 red LED's that are staying on? Anyway, sounds like you have an SI board problem, Jmarch and replacing the batteries may or may not fix the problem but you should try it first.
                  Thanks Barry, I'll give it a shot
                  1995 Porsche 993
                  2004 Ford F-150 FX4
                  Gone:
                  1985 BMW M635CSI
                  2001 BMW M3
