215 bhp motor vs 220 bhp motor
  • 215 bhp motor vs 220 bhp motor
    Sorry if this the wrong forum for this.
    can someone tell or give me a link that outlines the major internal differences iwht the euro 215bhp motor and evo 2 220 bhp motor.
    cheers,
    I Find your lack of faith disturbing"
    "Objects in my rearview are losing"
    different intake cam
    different valves
    different pistons
    different TBs
    different ECU
    different flywheel
    non cat
    Markus
      Thanks Markus,
      Is there a place I can source these items new or used if i wanted to build a evo2 motor cost?, if I already had the ecu & will the evo ecu work with a 215 bhp motor?
      different valves
      different pistons
      different TBs
      different ECU
      different flywheel
      non cat
      Markus
        Originally posted by 13blackknight View Post
        Thanks Markus,
        just a thought, if you are going to buy all these "EVO2" parts you may get more for your money if you select aftermarket parts.
        Everything labeled "EVO" has a special price tag which isn't always justified.
        i.e. insted of EVO cams buy a set of Schrick's 284/276.
        Or pistons. You will get some nice aftermarket forged pistons for the money BMW is charging you for EVO2 pistons.
        Your 215bhp throttle bodies (if you have them) are anyway larger than the EVO2' (46 versus 48mm)
        ECU isn't a problem either. They are all the same and do only differ buy the eprom used (swappable but can sometime require a matching chip/size, no problem really)
        I am sure you will find tons of information here if you use the search function.
        Search for
        Schrick cams
        engine rebuild
        custom chip (the igomotive seems to be everbody choice)
          Thanks for the reply,
          you make excellent point anything"evo" is costly in any country.:
          Cheers,
          Search for
          Schrick cams
          engine rebuild
