reinstall handbrake leather boot
  • reinstall handbrake leather boot
    Does anyone know how to reinstall the leather cover for the handbrake?
    i took it off to wash/clean it
    re-dyed the leather and applied some leather conditioner
    looks brand new
    but when i try to install it
    it stops the handbrake grip from going in all the way
    it just gets crimpled up
    does anyone know how its installed?
    or can someone take a pic of the joint between the grip and the leather?
    also how do you get the grip in all the way
    i tried with all my might to get it in, but it's still sticking out about 1"
    should i put something over and hammer it?
    Mine just slides down and snaps into place. Then I muscle the handbrake grip on after...a little twisting with both hands to get it all the way down. No real trick except to just put it on with a little force.
      looks brand new
      I typically pull the plastic handle off the handbrake lever.
      Insert it into the handbrake leather cover (while the cover is turned inside out), and then press it through the opening a bit. Turn the cover right side out, and it's rolled on the handle as it should be. Now install it onto the metal handbrake lever as normal.
      Takes a bit more muscle, but seems to work for me.
      -C
      Chris L.
