Check light for windshield washer?
  • Check light for windshield washer?
    My windshield wiper fluid resevoir is full and my sprayers work fine but I keep getting the check light. What's the issue here, the sending unit?
    "Condoms break baby, Deal with it."
    - Max Weinberg
    The float is probably shot, pretty easy to fix. HTH
    edro
      Yeah...you need a new sensor...
      Easy replacement piece...or just disconnect it and wire it so that its always reading as having fluid...
      I still have to do this as i no longer have my tank in the car...
      ADA///M
        Mine gave me trouble and it turned out that it just had a lot of crud stuck to it. Try taking it out and cleaning it off. It might still work.
          First I would try and rotate it, it can be turned the wrong way and act up.
          If not, then replace it.
          Do not click
          At least it's German
