Need help!!!!
  • Need help!!!!
    I hope this is posted in the right section? i was going in reverse today, while driving barefoot, and I got pissed on by my m3, fluid started pouring on my feet, it was (HOT). burnt me pretty bad. It had to be clutch fluid?? am i right,
    what is my problem?
    Coolant from the heater valve or core. Do a search. BMW had a recall in the early 90's for this very problem.
      Should be the culprit. Do a search as others have had this problem.
        i looked, i cant find any replacement parts for this, do u guys have any advice?
          http://www.s14.net/forums/showthread...er+core+bypass
          Chris L.
            Here is my thread about this.
            http://www.s14.net/forums/showthread.php?t=24465
            - gabor
            October 1987 build date.
              If you can afford to not drive the vehicle:
              Do a visual inspection of the heater core area (like gabor's post). If you can't find exactly where the leak is coming from, then take it apart. It could be an old O-ring, bad water valve, bad heater core, worn-out alu-pipes?
              Whatever the issue is, replace the O-rings at the same time.
              Make sure you select the right year when you are looking up parts here:
              http://www.realoem.com/bmw/
              I believe that there are different pipes for different years of production.
              Here are the images from the 12/88 build.
              Parts: 1, 7, 8, 13.
