oil seporator
  • oil seporator
    Any one know if i need the oil separator?
    I don't have a port on my oil pan and was going to run a catch can but since i have very little space I was wondering if i could get rid of the whole shebang and what I'd have to do hose wise??
    Jake
    you should search on this.... I know that I do not run mine... several people with the CF box have eliminated it... I am not sure that I know of folks who have removed it with a stock engine/intake but if they've done it, it's probably in the archives.
    Mark Williams
    Dallas, TX
      This thread discusses the oil separator function and removal. This link was posted as response to another question on the SIG email list this very morning! Good timing.
      http://www.s14.net/forums/showthread.php?t=12673
      Hope it helps.
      Dominic
        Thanks for the reply guys.
        I've been so busy my searching for 5 minutes didn't reveal much so I appreciate the link.
        still a bit confused though (tired 4am need to sleep)
        do I run the hose from the valve cover to a catch can and put a filter on the hose from the plenum?
        sorry if I'm not making sense must sleep and try again tomorrow.
        Thanks again,
        Jake
        Ok mark,
        I did a few more minutes of searching and its starting to make more sense.
        I really need sleep now.
        Thanks again.
          Think of it this way... any air into the plenum *must* come through the AFM or else you will have an unknown amount of air heading into the cylinders. So any ports off the airbox/plenum should be plumbed very carefully or sealed up.
          So... you could do hose from cylinder head --> catch can --> plenum. That would be the most environmentally friendly way. This also still pulls a vacuum in the crankcase. Another way would be cylinder head --> catch can --> filter. Then you plug the plenum port.
          One last thought, if you do feed the catch can back to the plenum, then you are opening a vacuum leak where the oil separator would drain back to the oil pan. You'd have to plug that connection.
          1987 Euro M3, Jet Black
            Get a generic one or get a nice Cusco or Greddy one.
            2002 Corolla CE Daily Driver
            www.TheTunerSource.com
