Revert to stock chip - no start
  • Revert to stock chip - no start
    I went back to the stock chip and she won't start. Just keeps on turning. I seem to remember when I changed chips in my 325is back in the day, it had some running trouble for 20 minutes or so until it smoothed out and drove like a champ. It had hard starting too.
    The chip was seated all the way, the ecu was connected and reconnected, etc. Seems like everything was square.
    When you guys switch chips, how long does it take to get it started?
    My chip # is 1267355785 fyi.
    Not sure if I've missed something...
    Edit-PS, after some searching, I found that there is a difference between some ECU's. 16 bit and 32 bit. The chip I have came from a 1/88 and the car it's going into is a 1/88. Via search, it seems my chip is 32 bit and it seems like my ECU may be 16 bit. What does this mean and does it matter?
    The ECU is plugged all the way back in? Nothing else is left unplugged?
    I would repeat the process.
    - gabor
    October 1987 build date.
      - gabor
      I did twice. I popped the other chip back in, fired up in half a second...to me this says either the chip is fried or incompatible.
        That isn't the original chip from the DME? How was the chip stored?
          No, the chip i used was from a past M3 I once had. I swapped in another 2.3L chip and it worked fine. Thew chip in question was stored in a typical chip case or whatever...however they are shipped from turner.
            Did you make sure to remove the battery prior to changing the chip?
              Check the chip itself, i know when i changed chips on my vw's i once pulled it out kinda at a angle and the little pins bent so when i went to put it in again it did not sit properly, check that.
              ///M Power
              "Dream as if you live forever,Live as if you'll die today"-James Dean
              Instagram- S14Pwr
                IIRC it has someting to do with 128k chips and 256k chips. Not 16 and 32 bits.
                  I didn't realize I needed to...I disconnected the ECU and brought it inside. I've never done that in the past and haven't had a problem.
                  I think bit may have been the wrong word. Now that I think about it, I saw 16k and 32k, not bit. I don't know what those numbers mean though. I think this incompatibility was the cause though.
                    is it in backwards (it rotated 180 degrees)
