Tire shredded at track
  • Tire shredded at track
    This happened at the track last weekend. Can anyone explain it? I have no idea why except it may have been a bad tire.
    Webb
    1988 Diamantschwarz
    2004 Jet Black
    Hard to tell from here, but it looks like the inside of the tire is more worn. Are you lowered or running more negative camber than normal that could have caused uneven tire wear? Possible the tire was starting to cord and you missed it?
    I guess you also could have hit something without knowing it, and that started it...
      The tire seems to have plenty of rubber left. Even if it was down to the cords, it should not blow up like this.
      Did you check the pressures before the session? I've had a similar blowout on the street which I think was due to a slow leak. Not noticing the lower pressure, combined with 3 degrees of camber, and highway speeds = Boom!
      -Luis
        WOW. looks like some of those tires at the Brickyard this past weekend
        Mark Williams
        Dallas, TX
          Spoke to a Toyo dealer here in DC area and he said most likely the tire was punctured during the session and was torn up like that as a result. Pressure started at 33.
          Webb
          1988 Diamantschwarz
          2004 Jet Black
            Guys... check out this video... http://abcnews.go.com/Video/playerIndex?id=4826897
            Fritz
            1987 Hennarot E30 M3
            http://www.youtube.com/watch?v=J2WsYARLD1Y
              Looks like it was under inflated, which caused it to overheat and delaminate. See the crease in the sidewall.
                The crease is b/c I had to drive 2/3 of a lap on the flat to get back to the paddock
                Webb
                1988 Diamantschwarz
                2004 Jet Black
                  If the track had concrete patches in the corners, I would speculate that the seams of the concrete/tarmac, were to blame, especially if this tyre was doing a lot of work.
                  W/O trying to start any negativity, I'll just add that a Toyo R888 delaminated/shredded at Blackhawk Farms raceway yesterday. It is believed that a newly laid concrete patch was probably responsible. hence my question.
                  I used Toyo RA1 on a similar car yesterday w/o issues.
