If anyone remembers, I posted a few months back that I suspect I have a blown head gasket. (The old thread is here: http://www.s14.net/forums/showthread.php?t=32634). The summer has been busier than I anticipated, so progress has been slow, but I've done a few more tests, and I still have no idea what I'm dealing with.
I did a compression test. I warmed up the engine, and as it came up to operating temp there was the familiar white smoke that keeps coming back, again only coming through the left of the two tailpipes. The smoke is white, and definitely doesn't smell like any burning motor oil I've ever smelled. It also doesn't smell sweet. I have never smelled burning coolant, but the smoke coming out has a terrible smell and makes it hard to breathe (it filled up the garage when the wind shifted direction)
On the warm engine, the compression results were:
Cylinder 1: 195
Cylinder 2: 191
Cylinder 3: 196
Cylinder 4: 195
As far as I know, the 5 psi difference between the lowest and highest readings is not a big deal, is that incorrect?
Also, all the plugs looked good to me, with a brown color to them. None were wet, and none looked steam cleaned.
After that, I decided that I would pressurize the cooling system, and see if it held pressure. I reasoned that since the smoke appeared when the engine was warm, it's possible that coolant is only leaking into the combustion chamber once it builds up pressure. I'm not sure how much pressure the system is supposed to hold, so I pumped the system up to about 15psi, not too high, but on the high side. It would bleed down to about 13psi, and then stabilize. I pulled the plugs, and looked into each cylinder, expecting to see coolant in one. I didn't, so I pressurized the colling system a couple more times, just to make sure that if it was leaking, enouch would get into the combustion chamber so that I could see it. Still nothing, everything looked dry in there. I turned the engine over by hand a few times, with the hope of sloshing coolant around in the combustion chamber so I could see it, still everything looked completely dry in there.
So, I don't know what to do next. In my previous thread someone suggested that it's possible that I have bad seals in my brake master cylinder, and the engine is sucking in brake fluid through the vacuum booster. Does this sound like a possibility? If so, will removing the vacuum hose to the booster eliminate this problem?
Thanks, and sorry for the long-winded post.
Cylinder 1: 195
Cylinder 2: 191
Cylinder 3: 196
Cylinder 4: 195
