Fan Clutch Question
  • Fan Clutch Question
    How do you test the fan clutch? It is not specifically for the E30 M3 but it is for my E39. When I stop at the signal light for about 5 to 10 sec, the water temp gauge move all the way to the red zone (within 5 to 10 second). Right after I start moving, the needle went back down to middle (normal temp) again within 5 to 10 sec. TIA
    Born date 01/88
    Ryan
    When heated up take a newspaper and roll it up. Stick it into the fan. If you can stop the fan the clutch is toast.
    Dan
    88 M3
    Black on Black
    San Diego, CA
    USA
      shouldn't the electric fan turn on at that point, meaning before it gets to the red zone.
        I did not notice the elec fan on or not, but just did the newspaper test and yes the newspaper stop the fan easily :( Listed at $196, ouch.
        Born date 01/88
        Ryan
          Check for prices at Tischer BMW:
          http://www.trademotion.com/partlocat...72&catalogid=0
          They tend to have very good prices and prompt shipping
            I've been using the 5-series fan clutch at $70 for the past 4 years. Roughly 15K miles on it, with street and auto-x and so far it still does the job.
            Consider it.
            zhpregistry.net
              Which 5-series? E39 or E34?
              Born date 01/88
              Ryan
                P/N 11521466000
                I believe it's from a e28.
                Edit: I am sorry, I didn't read your post well enough to realize that it's your 5-er clutch that's gone. I don't believe the part # is interchangeable for the new 5 series cars.
                zhpregistry.net
                  5 to 10 seconds seems like a pretty quick time for the engine to jump into the red just from coming to a stop.
                  Seems like the car might be running a little hot to start with...anyone else agree?
                    Agree, that really bug me a little of how fast the gauge go up and down.
                    Born date 01/88
                    Ryan
                      yea, well we all know how inaccurate the temp gauge is. Yes, the car is most def running hot without a proper working clutch fan. The lack of moving air just pushes the temp up enough in 5-10sec to move the gauge to red. You aux electric fan should turn on with in the red zone.
                      www.ZeppieriMotorsport.com
                      E30 M3 Rebuild Thread
                        You might want to start by unlocking your cluster. Search the e39 boards to find out how to do it. Once you see the actual coolant temperature, you'll have a better idea of what's going on.
                        Have you had any work done on the cooling system lately. If so you might have air in the system which needs to be purged. Is your auxiliary fan working? Have you checked the plug that goes into your thermostat? They tend to melt on the 4.4L engines on the e39 and e38.
                          Will unlock the cluster to see what is the actual reading is. tonight.
                          I did replaced: thermostat, water pump, radiator about a year ago (radiator neck broken, very common issue so I replaced the rest as a preventive maintenance)
                          Born date 01/88
                          Ryan
                            What if the thermostat stuck closed all the time? I know if it stuck open then engine running too cold
                            Born date 01/88
                            Ryan
                              It is possible on the thermostat. I've been thinking on my side of just running the aux fan sooner, and getting rid of the manual clutch fan.
