I am experiencing a little vibration at 55km/h and at about 65km/h it seems to go away, below 55km/h I also dont feel the vibration...it seems to be coming from the propeller shaft...anyone experience this?
vibrations @ 55km speeds
Justin, maybe you just have to get your wheels balanced? Btw, what makes you say it might be coming from the driveshaft?
Yes. you should mark the driveshaft before removing it... That can be balanced but I don't know of any shops in Cebu.. Is Dogleg (Choms?).
I think justin means the propeller shaft and not the half-shafts..?
kiko,
about the dots...only problem is I did not personally check it myself after the installlation, so I guess the mechanic missed a tooth, I will check it again when I get the car lifted....
Originally posted by fritzjuan View PostYes. you should mark the driveshaft before removing it... That can be balanced but I don't know of any shops in Cebu.. Is Dogleg (Choms?).
