I got my car back from Split Second Performance in Santa Ana and it's running quite a bit smoother.
On a Dynojet I put down 180hp and 166lb-ft at the tires. This about what I expected (not much), as I'm only using mostly stock 2.3L equipment on a 2.5 bottom end.
I also started to run out of injector somewhat over 6500rpm.
Specs are as follows:
Evo3 pistons and crank
Evo lightweight flywheel
Maxx A-N
CF Intake manifold and CF filter housing w/ large K&N cone
Stock 2.3 head, throttle bodies, cams, FPR, injectors
TMS 2.5 chip*
*This specific chip (there are other TMS 2.5 chips, as well) allows you to run a 2.5 bottom end w/ 2.3 injectors and 2.3 AFM. Basically it modifies fueling but leaves timing relatively unmodified (so I'm told). As such, maybe some horsepower is left on the table because of the changes to the intake system; also it doesn't do me much benefit since I have MAXX A-N for my fueling.
Anyway, I do have plans to upgrade the engine so it can make better power. But this is a start. I have a smog test coming up, and I wanted to make sure to pass, as I'm still learning how to tune.
I'll try to post a pic of the graph over the next few days, if anybody's interested.
Maxx A-N
TMS 2.5 chip*
