Split Second ARC-2A - MAF + Piggyback ECU
  • Split Second ARC-2A - MAF + Piggyback ECU
    Does anyone here know of, or use, the Split Second ARC-2A?
    http://www.splitsec.com/products/arc2/arc2A.htm
    I did a search here on the forum and wasn't able to find any threads referencing it, but I assume that someone here knows this item...?
    Would this work as a replacement for the factory AFM?
    -AJ
    -'88 Henna Red-
    Slpit Second
    I have no remote usage of this unit, but do know of people who tended to forget to adjust the dials from time to time and the end result was a fatal engine.
    I'm a fan of a tuned system of set and forget. Pay up front as for the cheap way around could cost you more.
    Chicco
      I use the PSC1-004 Programmable Signal Calibrator. This allows you to replace the factory AFM with any MAF you choose as long as the MAF is a 5v MAF.
      The ARC-2A looks like you use dials to tune the fuel. The PSC1-004 is programmable with a laptop. I haven't had any issues with my unit so far.
      Pat
