Failed CA smog: [email protected]
  • Failed CA smog: [email protected]
    Hi-
    I failed my first CA smog test and Juan at SBI suggested I post the numbers up here so he could take a look. So I don't think I'll need input unless you're so inclined.
    !5 MPH; 25MPH
    %CO2 MEAS 14.1; 14.3
    %O2 MEAS 0.2; 0.0
    HC (PPM) MAX 118; 93
    HC (PPM) AVE 31; 20
    HC (PPM) MEAS 51; 35
    CO% MAX 0.75; 0.63
    CO% AVE 0.10; 0.09
    CO% MEAS 0.13; 0.07
    NO (PPM) MAX 799; 738
    NO (PPM) AVE 237; 199
    NO (PPM) MEAS 894; 513 FAIL
    Relevant service history (current mileage 88,000):
    7/2002 62,631 distributor cap, rotor, ignition wires, air filter
    7/2003 65,517 adjust valves, throttle bodies, co, clean throttles
    4/2005 68,190 change fuel filter
    11/2006 72,689 replace thermostat
    6/2008 83,000 change spark plugs
    11/2008 87,450 replace oxygen sensor
    Relevant mods:
    Evo airbox
    Evo exhaust cam gear
    VSR center section
    Eisenmann muffler
    Barometric sensor disconnected
    usually run TMS chip, but replaced with stock chip for emissions test
    I think that's pretty much it, except that I've always thought it's run a little rich given soot on the back end. Any help appreciated.
    Mark
    Mark
    "She'll hold together. Hear me, baby? Hold together!" -- Han
    All I can add is that I passed my last california smog using my Turner chip. I just tuned the alpha N map to perfection.
    - gabor
    October 1987 build date.
      get the car much warmer. Try to get it on the rollers immediately.
      You can also try pulling one of the caps on the throttle bodies.(just one)-worked for me
      Good luck!
      Thomas-
      1991 E30 M3 Diamondschwartz S50B32
      1998 E36 M3 Turbo Sedan Six speed
      CLK63 BS
        One question..........................How old are the Cats?
        David
        Redwood City, CA
          Cats replaced with the center section about 23,000 miles/5 years ago.
          Mark
            I just passed my Smog.. Barely!!!! I have turner chip with strumhong exhaust. I drove the car at above 6000 RPM for about 10-15 minutes and took it to the smog guy. luckily there were not many people there so he put it right away and I passed. you should run it hard to get the cat nice and hot, so it can work extra hard. luckily, this give me 2 years before I need to change my exhaust and cat.
            :burn:
              Your cat is still good. You're just running a little too lean. Either rich it up a little bit or warm up your cat a little bit more and you'll pass.
              1989 M3 (till I die)
              1987 325iS (sold)
              1985 325e (sold)
              1984 318i (sold)
                Huge props to Juan at SBI who used fuel injector cleaner, richened it up a bit, and actually went to do the smog check with me! It passed, but barely. Still running lean.
                I highly recommend SBI for anybody near LA.
                Mark
                Mark
                  You mean Hoa right? (wah) Vietnamese guy.
                    ^ i believe he does...Hoa and Thang super great guys. part of the reason why I drive bmw
                    "Hearing the metallic clatter of the valves, the wind, tire and road noise....the endless stream of morse code that comes through the seat bottom and steering wheel. It's amazing."--:OMG:S14addict:OMG:
                      Not only super great, super honest too
                      Born date 01/88
                      Ryan
                        Yeah, I was wondering why a Vietnamese guy would be named Juan. But, hey, its LA so I didn't ask. Hoa rocks.
                        Mark
                          +1 for Hoa at SBI. He's an excellent tech and very trustworthy.
                          (His name is pronounced similar to "wah"--a note for the whiteboys like me )
                            Another plus for HOA and SBI, they've been working on my car for years now and I wouldn't take it anywhere else even though its 40 minutes away from me. These are the guys that make me want to drive a BMW forever.
                            AST Suspension | Facebook | Blog
