Anybody has pics of IE stage III and H&R race springs installed in their car?
  • Anybody has pics of IE stage III and H&R race springs installed in their car?
    Hello
    I am trying to decide which spring set to get.
    Ireland Engineering Stage III race or H&R race springs so I was wondering if I can see a picture of your cars with those springs installed so I can compare.
    I understand that those springs are pretty much the same so I am looking to see which one has more even drop look.
    If you are posting pictures, please also mention which shocks are installed
    Please post the pictures in this thread or email them to [email protected]
    Thanks in advance guys
    1989 M3 Cabriolet "Reproduction" #787th?? :-)
    IE stage IIIIE stage III
      wow, I like the look a lot. Which shocks are installed on the car?
      I like the look a lot. It is very even. Did you use the standard e30 m3 spring pads in front and rear?
        IE stage III w/Bilstein sports. F+R spring pads are removed. I would recommend considering Koni adjustable instead of these bouncy Bilsteins. my 2 cents.
          I think it is a good idea!! Konis are more expensive though!
            H&R Race with one coil cut on the fronts with 225/40/18 tires.
            Here's mine with H&R Race with one coil cut in the front with 3mm pads and on
            225/35/18 tires. Mine has the S14 in it and the red one has a S50 swap.
              Thanks for the pics. very nice!!
              May I ask why did you cut a coil in front?
                Car sits a little high in the front with the H&R Race springs. I may end up cutting
                another half coil off the front to get just a bit lower.
                  Yan and Chutrain feel free to post those pics with your suspension info in this thread. it would help compile more information! thanks!!
                  http://www.s14.net/forums/showthread.php?t=36431
                  Real M3s have 4 Cylinders
                    Now we need pics w/ H&R races w/ no springs cut to see the difference . Interesting!
                    Mike
                      That's right. H&R race with no spring cuts pictures please! :-)
                      I think I am now leaning toward IE stage III springs because they have 2" front drop vs. 1.6" front drop of H&R race. No more coil cutting I guess.
                        Sorry its not a dead on side shot, but its all I have right now. Mine has H&R Race on Bilstein sports. Wheels are 17x8 w/ 215/45/17 RE01.
                          Thanks a lot SacM3
                          Your car looks good with H&Rs and white is my most favorite color!!
                            Quick Q for the guys running the Race springs. What kind of suspension travel do you have? What shocks? and are you running the factory bump stop trimmed(how much) I just threw in the H&R race with the Koni sports with the bumpstops trimmed to right about 3/4 inch total length. It seems that theres almost zero travel. i'm wondering if i can run without the bumpstops to get a little bit of travel out of the setup. Wheels are BBS RGR's 17X9's 235 Toyo R888's
                              I have decent travel with the Bilstein sports, but I know what you mean about reduced travel. (It doesn’t' take much to bottom out the shocks on the street). It really stems from lowering the car by 2" and not having shorter shocks/strut tubes with a different spring perch height. The ideal way to go for travel is the GC way of cutting the tube down and then putting a shorter shock in there.
