Starting problems
  • Starting problems
    When my car is cold it starts fine. But after driving a while then shutting it off for 15 minutes or so it takes a long time to start. It also turns over very slowly on the first try sometimes. If I let it go then try it again it starts fine. Is this a fuel problem or what?
    check your oil level
      Oil level is fine.
        Hows the battery?
          Not even a year old & this problem started when it was warm.But I will do a voltage check on it.
            I have a very similar problem with mine. If my car sits for a couple days and I try to crank it up it hesitates a little and then starts up. After she warms up, it starts up with out a hitch.
            Prin7
