Anti-Lock light on
  • Anti-Lock light on
    hey my Anti-Lock light came on i was told that it might be a relay do you guys know wich relay it is
    Thanks for any help
    I think the relay's are a PITA to get to - they are behind the plastic shroud, behind the coolant overflow tank on the fire wall. I'm trying to get in there to get to my fuel pump relay, it's like fort knox - They look like this:
    $27.95 at Bavauto
    >>>>> Edit: Wait, I'm not sure where they are located, Bavauto says that they are under the dash. Hmmm.
      $27.95 at Bavauto
      nope, the main, fuel, and purge valve relays are behind the coolant reservoir. the ABS relay (if equiped) will be found clipped to the ABS ECU just left of the steering column
      since you have an '88, you should have the relay. i do not since later wiring harnesses eliminated the relay
      James
        ^ Thanks for confirming the location
          There is a fuse wire in the relay which 'blows', common issue.
          Schwarz 1990 Sport Evolution
            and another fuse wire in the ABS ECU as well (Martin H found that after a loooong time of searching)!!
              thanks all will look it to it this weekend
                You might also want to check and clean off all four sensors at the corners. Its pretty common for them to clogged with magnetic schmutz and trigger an error light.
                MJ
                  MJ
                  I think there is only 2 sensors and did replace them when i did the brake job
                    oh really? i figured there is one in there, since on my car BMW eliminated the external relay, and it would surprise me if BMW powered any ECU directly off the batt. did he repair it?
                    nope, there are 4 ABS sensors. maybe you're confusing those with the 2 brake pad sensors?
                    James
