Anyone dealt with a creaky/squeaky brake pedal?
  • Anyone dealt with a creaky/squeaky brake pedal?
    My brake pedal makes a squeaky/creaky noise when pressed. The noise seems to be coming from the area near the top of the pedal arm and not from the foot pad itself. Does anyone know what needs to be taken apart and lubed? Thanks!
    That is most likely the return spring creaking.
    "Never lift"
      Spray some WD-40 at the upper pivot and pump the pedal. That's what I did.
        Sounds easy enough. I'll give it a "shot". Thanks!
