DIY for GC Camber Plates Install?
  • DIY for GC Camber Plates Install?
    I have never messed with adjustable camber plates. Neither installing them or setting them.
    Is there a write up anywhere?
    Not that I know of....what are you having trouble visualizing?
      How everything goes together. What attaches to what.
      I am a noob when it comes to these things so take it easy on me.
          If I remember correctly GC has a pretty good picture on how they go together. Starting from the top and working down is the main plate with markings, Then next is the plate with the threaded holes for the allen bolts, then there is a bushing, then last is the "CL shaped bracket that holds the top plate to the strut tower. "I think". I can't get to my car right now to make sure.
          "Racing is like life, what happens before or after is just waiting." - Steve McQueen (Le Mans)
            This is a really simple install. Shock goes mounted to GC Camber plate via a 19mm nut. Then the plate goes mounted to the shock tower via 3 13mm nuts. That about it for install them.
            Adjusting you need an alley key(i dont remember the size).
            www.JOEBMWMotorsport.com
            JOEBMWMotorsport
            E30 M3 Rebuild Thread
            BMW & E30 M3 Parts and Services Specialist
