Valve cover?
  • Valve cover?
    Hi all. Do I need to replace the valve cover gasket if I remove the valve cover for
    repaintaing? The gasket was replaced 10k mi ago.
    Robert
    You don't need to but it may not be a bad idea.
    I didn't replace it even after removing it a couple of times and it never leaked.
      My experience has been totally opposite... I repainted my cover then tried to reuse my gasket, drove the car about 6 mi. and had oil puddles in each of the spark plug holes and rear by the coolant resevoir. All over $20 worth of gaskets... Not worth the drama IMHO.
        +1 same here. Cheap preventive maintenance
