Wattage Increase for Gauge Cluster?
  • Wattage Increase for Gauge Cluster?
    Based on a search I've seen a suggestion to swap out the two 3 watt main bulbs used to illuminate the gauge cluster for 5 watt versions (side marker bulbs).
    Does anyone have a feel for whether the circuit/wiring is robust enough to reliably handle this?
    Thanks in advance.
    Well for anyone interested, a search on bimmerforums indicates a few people that state the 5 watt bulbs throw too much heat. So much for the easy way to brighter gauges.
      Perhaps the LEDs with the wide angle?
        The 5w will melt the orange caps - not a good idea!
          Thanks for the input guys.
          I thought about LEDs but decided I wasn't motivated enough to make that conversion.
          As an alternative, I made a few small holes in the orange plastic "hoods" (caps) that cover the two bulbs to try and allow a bit more light through. Thought I'd try this based on some people that have reported good improvements by removing the two "hoods".
          I also installed aluminum gauge rings at the same time which appear to reflect the light a bit. So, it's hard to actually quantify the delta but it appears noticeably better now - I'm happy with it.
            I tried white LED's once but they ended up looking even dimmer because the orange caps and filters blocked the light output. I ended up just putting in fresh 3w bulbs. I was going to try the orange or yellow LED's the next time I pull the cluster, but haven't done it yet.
            88 M3 - 04 LS430 - 03 SL500 - 95 E320 - 70 Mini Cooper
            RC Wheels by Team Pogi
            like us on facebook
