Looking for some fuse #9 help
  • Looking for some fuse #9 help
    So the white M I did an engine swap is still giving me some difficulty. I've tested the ECU, MAF, TPS, Coolant sensor and O2 all are working fine yet Fuse 9 is popping and coolant is not getting to 180 degree operating temp so I'm replacing the thermostat. But what does #9 do?
    I have great pressure and the car is running Rich.
    #9 is a 15amp fuse for the Idle Speed Control (according to the Koala Manual)
      So it controls the IDC odd cause the car runs great at idle it's only when pulling away from a stoplight or a semi partial throttle.
      I will take a look at the ICV and the wiring for it.
        sell it to me, that will solve your fuse problem[peace]
        they are not idiots.
          Greg,
          what year? My BMW schematic for my 89 show fuse #9 for evap purge relay and diagnostic connector.
          81 Ur Quattro
          87 911 M491 Cab
          89 M3
          89 944 T
          What can I say,
          I love wide fenders!
            Evap purge relay is furthest out board of 3 relays on bulkhead behind the coolant resevoir tank. It has a built in resistor so you can swap with another for fuse testing but will need a dedicated unit for long term replacement.
            81 Ur Quattro
            87 911 M491 Cab
            89 M3
            89 944 T
            What can I say,
              Mike it's an 88 model. I was wondering about the Evap system being overloaded but now that is something to look at as well.
                Buy my fuse decal so you don't have to ask what those fuses are for
                  Bing if you look at your decal it states only one function Fuel Electronics.
                    Ooops.
                    Lawrence
                    '90 M3 AWII - Garage Queen
                    '03 530i 5 Spd - SO's DD
                      What motor swap is it and hard wired or plug and plaY? Idle speed & pump are fuel electronics.
                        I put a 2.3L s14 back in it. It only had a 2.5L lower end in it that had some damage so that's the winter project if I get a spare head.
                        I put a EU wiring harness in it due to the remnants of the factory harness was butchered for MegaSquirt.
                          Check this link:
                          http://shark.armchair.mb.ca/~dave/BMW/e30/e30m3_88.pdf
                          Suggestion:
                          Check for any corrosion on leads, wires (anything fuse 9 related) , usually bad ground causes fuses to trip. If you have patience trial and error each item
                            I'm working on page 13-750 but it's slightly confusing. Next is checking the ICV and going over the evap purge setup again.
                              Greg,
                              1364-6 is the sheet for fuse #9. Pretty staright forward to track if you have short to ground or a bad relay in the circuit. I'm bad @ electronics but it seems ICV control comes off the ECU versus a single fuse?
                              81 Ur Quattro
                              87 911 M491 Cab
                              89 M3
                              89 944 T
                              What can I say,
