questions, alternatives
  • questions, alternatives
    i am rebuilding my s14, and it is becoming very expensive....sorry..
    i need Chain Tensioners (the expensive ones) are there any other alternatives? or are these the only ones for this motor, might be a stupid question, but just wanted to know before i drop 600.00 for pieces of plastic....thanks for the input.
    There is no way around the plastic rails that I know of. The beauty of the S14 motor
    is that nothing is cheap.:evilnah:
      Rebuilds are expensive on these motors, those with shallow pockets do swaps.
      The masochists keep rebuilding the S14, like me.
        It's easy to see why people swap once you get into the nitty gritty of an S14 rebuild but those rails are the more expensive parts of the engine for what they are. We should find a way to reproduce/remanufacture them. It's just the rubber part that wears down right?
          agreed with everything you have said, this is a bitch.....but we will be close to finishing...
            I think those parts are just something you need to suck up and buy, even though none of us like it.
            I don't think getting the part duplicated would save significant money, even if we could find a place to do it.
              The plastic itself becomes brittle over time. Usually when they fail pieces break off. Reproducing would be a pretty sizable undertaking. Especially when you consider the implications of failure.
                It would be cool to convert the rail to needle roller bearings
                Like that would be cheaper...
