"M3" Badge on Trunk Lid
  • "M3" Badge on Trunk Lid
    I removed mine to facilitate buffing the paint on the trunk lid.....
    Any recommended adhesive for putting it back on? If I order a new one, does it come with adhesive?
    Mine is slightly faded, and I am on the fence between putting it back on and ordering a new one.
    Thanks!
    Use 3M double stick tape and try this
    http://forums.bimmerforums.com/forum....php?t=1285316
      Once you are ready to reinstall the ///M3 emblem be sure to place it in the correct position.....one thing that really bugs me is when I see boot emblems in the wrong position...ruins an otherwise perfect "rear end" :-)
      The manual shows the exact dimensions (per factory spec)...I'd try to get it as close as possible if I were you.
      If you don't have this spec let me know, and I'll get it to you.
      Good luck,
      Thanks!
        Rear emblem placement here
        +1 on the 3M double sided tape
        HTH
          If your emblem is really faded and it bothers you, replace it now. It's the perfect time. New emblems already have adhesive.
            Fit new and forget! be good...Ted
              Go new...thats my thinking.
              www.ZeppieriMotorsport.com
              E30 M3 Rebuild Thread
                Thanks James.....that and the other diagram is what I was speaking of.
                HTH
                  Don't bother refit. Get a new one, cost less than buying the 3M tape anyways!
                  1987 BMW M3 E30
                    Thanks for the input guys......
                    I'm going "new"!:partay::fyeah:
                      What??? Either you get ripped off with the 3M tape or you haven't been to the dealer asking how much a genuine M3 badge is.
                        I got mine from Bav Auto.....around 27 bux with tape.
                          Is that for the "///M" and the "3"? If so, that's cheap!
                            I just got my decklid repainted and the specs ITT really helped me with the placement of the M3 badge. Thanks guys.
                              You're welcome....it's the little things! :-)
