Camber & Toe rear
  • Camber & Toe rear
    Is there any known way to fit something that makes it possible to adjust a bit on the camber and toe at the rear?
    I have seen some funky bushings with some funky bolt stuff on Bimmerworld I think. How does this make it "adjustable"?
    I have 3 degrees on right and 3.5 degrees on left rear negative camber.
    Toe is "ok", could be a bit more toe maybe but it was inside the criteria. Had the car to wheel alignment today.
    I want the tire to be worn just a bit more towards the center. Now it's just wearing the inner 3 cm. Changed left to right today so I can just use what is left of them.
    1987 BMW M3 E30
    May I suggest to use the search function...
    http://www.s14.net/forums/showthread...amber+Toe+rear
    Thomas
      I just did mine a few months ago and used Ireland Engineering Adjustable rear camber kit. I have some pictures if you want to see how they look after installed, I just have to find them. The only thing is you will have to remove the entire rearend and have it welded on. Below is the web page I found.
      http://store.nexternal.com/shared/St...ID=&GalleryID=
