Brake Fluid Reservoir relocation.
  • Brake Fluid Reservoir relocation.
    So most of you guy with CF airboxes will have done this, so what did you do about the clutch fluid pipe that goes on the side of the stock one?
    Did you use a separate reservoir for the clutch and one for the brakes or just join into one of the pipes that goes to the brake master cylinder with a T piece connector or something simular?
    hi
    look here
    hope these pics helps you
    Markus
      Markus, what does the clutch fluid pipe connect to? Is there a connector on that reservoir for it? You can't really tell from those pictures as you just see the pipe go behind the reservoir. I believe the ones I've got on order are from 2002.
        Martin, its from a BMW 2002. you can choose to reuse
        your M3 cap (so you have brake fluid sensor signal) or not.
        you need the 2 little nipples with some hose.
        you will need to do a full brake bleed after the install.
        If you need part numbers let me know.
          here are better pics.....
          i hope you see it now where the place is for your pipe
          Markus
            Thanks guys I can see where it all fits now. I wasn't sure is that reservoir had the connector for the clutch pipe or not. But it's clearly visable on that last pic.
            Part numbers would be great if you can dig them out for me John
              Reviving an old thread....
              I have a CF intake and am looking to relocate my master cylinder as above..
              Does anyone have part #s for the Master Cylinder reservoir and ideas on where to get the plugs for the Master cylinder?
              Mark Williams
              Dallas, TX
                the answer was sent to me in PM so here it is..
                34321112399 brakefluid reservoir
                34321102282 hoses - need 2
                34311121911 rubber grommets for master cylinder need 2
                all parts come from a BMW 2002
                Mark Williams
                Dallas, TX
                  Thats how I did mine.
                  Link: http://gallery.s14power.com/displayi...album=37&pos=0
                  Thomas
                    old revive again. I am using the 325ix MC and need to relocate the reservoir tank. I assume that hose/nipple combo will work for the 325ix setup as well?
                      I have a slightly used correct for the relocation 2002 reservoir if anyone needs it.
                        I will; revive this thread as well but I am curious on the part number for the stock rubber grommets for the master cylinder and that being said I have a relocation resevoir, grommets and hose for sale?
                        Thank you,
                        Tyler
                        http://www.europeanplates.com S14.net 10% Code: s14
                        http://www.europeanplates.net Build and Preview plates
