Just installed H&R Sports from stock springs. Thanks BMWCAW (Thumbs Up). I measured a before and after height. The Fronts dropped just a little over a half-inch. The Rears dropped a little almost a inch. Are they going to continue to drop over time? What other methods can be done to make a significant drop as advertised? How much is a 'significant drop' for you guys?
H&R Sport Springs
H&R Sport Springs
Lawrence
'90 M3 AWII - Garage Queen
'20 X5M - Son DD
'03 530i 5 Spd - SO's DD
'03 Nissan Frontier Crew Cab - My DD & Down Range truck
Tags: None
I am satisfied for an inch drop since that was advertised by H&R. But barely a half inch is something else. Am I being naive here? I was told Race Springs are really a significant drop. However, ride comfort would be compromised.Lawrence
'20 X5M - Son DD
Originally posted by Das Boots View PostJust installed H&R Sports from stock springs. Thanks BMWCAW (Thumbs Up). I measured a before and after height. The Fronts dropped just a little over a half-inch. The Rears dropped a little almost a inch. Are they going to continue to drop over time? What other methods can be done to make a significant drop as advertised? How much is a 'significant drop' for you guys?
does anybody have any part number for the thinner spring pads for the rear? I left my top ones on but if I could find like a 3mm or 5mm instead of the 10 that there is now it would be alot better.@slowprogress
Originally posted by JZM3 View Postdoes anybody have any part number for the thinner spring pads for the rear? I left my top ones on but if I could find like a 3mm or 5mm instead of the 10 that there is now it would be alot better.Lawrence
'20 X5M - Son DD
^ removing the top pad takes away a nice amount of mm. I think mine were 10mm, I cut one coil off my brand new race springs and took the pad out. Some say there is noise due to the fact that you take off the pad but I don't see any difference with it there. If I were you I would start by removing the top pad and see if that's the drop you want.@slowprogress
