Heater Matrix
  • Heater Matrix
    Guys, I'm changing the carpets on the M3, and wondered is it worth changing the matrix while they are out? Car has been well maintained but i guess thats no guareentee it wont go pop 2 weeks after fitting the new carpet. :wahwah:
    I think ive answered my own question.....
    Another question, apparently theres two types of matrix on the M3, and the dealer cant tell me which ones mine. Apparently ones is metal, the other has plastic unions. Does anyone happen to know which one os most likely? (German import on a '90 plate)
    Cheers,
    Warren
    If the carpet is out, look at the pipes going through the firewall. If they are silver, and appear to be aluminum then you have the aluminum version.
    If they are black, then it is the plastic version.
      Replace it.
      There have been several instances of people springing leaks from the heater core valve, myself included this past summer.
      Where did you source the new carpet? What colour?
        I'll be doing this job soon aswell. My water valve is starting to leak...
          Carpet isn't out just yet so was hoping there was another I could tell so I could hit the lot in one day. I ought the carpet from the BMW dealer. The front is black (silver / anthrazite nla) and the rear in anthrazite which I'm going to get pro dyed to match the front. I've found someone who can do it without getting it emersed in dye.
            Buy the original manufacturer matrix off
            http://www.c3bmw.co.uk/
            It'll be cheaper and you'll get the right one.
              How much was it?
              James
                Originally posted by Quest View Post
                How much was it?
                Carpet was approximately £450 all in (front and rear) Ive given up trying to match the bot sectrions, and dyeing is the only sensible route to achieving a carpet with the same colour. BMW need a good kick up the arse! :nope:
                  Supplying BMW parts and accessories direct to the BMW enthusiast since 1978,
                  I normally use C3 for everything, but admittedly i was going to go the dealer as ive had to go for them for everything else. Thanks for reminding me. :-)
                    Replace that heater matrix, its money wisely spent!
                    Mine (Euro 1990 170'000km) went bang (literally) last year on the Nordschleife, it is quite a time bomb apparently...
                    Thomas
                      You may also want to look at changing the heater valve while you are in there. If that 'pops' it will fook your carpet, same way.
                      Schwarz 1990 Sport Evolution
                        Thanks guys. Its a defintate no brainer then. Just wish i could order before ripping it apart.
                          All you have to do is remove the underdash panel in the left side footwell, shine a torch towards the firewall and look for two tubes penetrating the firewall. If they are aluminium, you need the later matrix/heater valve. 2minutes , tops.
                            Cool, thanks mate, ill give it a try.
                              You have a 1990 MY car so 90% odds you have the latter kit.
                              10% is if some muppet before you switched it out to the pre 1989 kit.
