Tachometer & Temperature Gauge Bulbs Out
  • Tachometer & Temperature Gauge Bulbs Out
    I have been driving with the Tachometer & Temp Bulbs out. I pulled the cluster to change the Odometer gears and decided to change the bulbs. Prior to closing up the cluster, I checked to see if bulbs worked, but both bulbs were still out. I double checked to make sure the connections were tight and the wires were in the housings. Also, switched the bulbs between the Speedometer and Tachometer and only the Speedometer bulb worked.
    Any idea on what to try and where to go next. My gears are due from Odometergears.com next week and would like to have a plan when I pull the cluster.
    Dan
    You should be able to find it here: HTTP://www.bavauto.com/shop.asp. If not go to your local junkyard and pull as many as you can from e30 clusters. Good luck!
