Block Strengthening Plate
  • Block Strengthening Plate
    Does anyone have any information on this? It goes above the MS oil pan. Any part number? Yes, I did a search.
    Several E30 M3's.
    I am not sure exactly what information you are looking for...?
    I have seen block stiffening plates on a lot of Japanese 4cylinder engines, but generally only on those with aluminum blocks. Their function is to keep the main bearing caps as rigid as possible in relation to one another.
    I am not certain how much benefit this would be on the S14, as I think the block is already regarded as being pretty rigid.
      Maybe a good thing for the older version 2.5 or 2.3 as the 2.5 blocks from BMW are much stronger around the main bearing bolt mounting area. I'd be interested if anything is found.
      E30 M3 Sport Evolution Black
      E30 M3 Sport Evolution Red
      E30 M3 Evo II Red
      E30 M3 Evo II Blue
      E30 M3 195hp Black
      E30 318 is White
      E30 318 is Red
        I can get one done if you are interested.
        Esa
          this here?
          Markus
            Originally posted by Markus View Post
            this here?
            Markus
            I really question how much that design of plate would do....
            The ones I have seen on Japanese four cylinder engines always tie into the main bearing caps.
              I've been looking for one also. It really helps the turbo cars, and probably the DTM, high-rev, high power engines too, since they ran them.
              Are they available, Markus? I can get them from Sweden, but they require a modified setup if run with the Evo oil pump.
              Anders
                My thoughts is that they would tie the main caps not like a plate as Markus has shown. I have never seen anything of the sort on an S14, Group A cars I have seen, and DTM cars I have seen. Not that it doesn't exist but...
                The Plate Markus shows looks like it would go where a scraper plate for windage would go. I do not see how this would add any reasonable amount of rigidity as it would be sandwiched between gaskets and does not look thick enough. The stiffening would be negligible.
                Cheers.
                -Matt
                  That one looks similar to this one. I think its genuine Motorsport..
                  http://www.s14.net/forums/showthread.php?t=37750
                  BTW, anyone have one of these...
                  http://cgi.ebay.com/ebaymotors/BMW-2...#ht_500wt_1182
                  Looks even beefier.
                  My M3 Blog Updated Regularly!
                  E30 M3 Wiki
                  My Youtube Channel
                  E30 M3: 14 Days to Victory Page
                    I share that opinion. It isn't a proper mains girdle.
                    The 7-bolt 4G63 in my Mitsu EVO VIII comes with a heavy, cast iron mains girdle like so:
                    Something like this is needed to effectively prevent mains walk. But then again, this discussion is hugely academic to a 200-250whp NA street-grade 4-banger.
                      m3guru, the auction you linked for the crank scraper shows one made by these guys:
                      http://www.crank-scrapers.com/bmw.html
                      They even have one with self-clearancing teflon scrapers.
                        I have a gruppe A oil pan and the reinforcement plate is needed to get the proper clearance between the sump and the pan. Where can I get one?
                        Several E30 M3's.
                          this here?
                          Markus
                          Yes. this one.
                          Several E30 M3's.
                            Thanks Colin.
                            E30 M3 Wiki
                            My Youtube Channel
