Engine bay cleanup
  • Engine bay cleanup
    Hi all, I wanna give my engine and bay a cleanup and was going to use Gunk or some similar degreasant then wash off with water.
    If this safe to do, or do I risk getting water in places it shouldn't go or damaging gaskets?
    And should I re-coat anything aftrewards to stop corrosion?
    thanks
    Mark
    '90 M3
    '58 Austin Healey Sprite
    '02 Suzuki SV650S
    I've used that method to clean my motor several times. I didn't do anything special, just sprayed it on, gave it some time to penetrate, then hosed it off. I just tried to keep the water away from any major electrical components. It's also helpful to let it dry for a while before starting it.
      I use gunk or similar: spray or brush on, leave to soak and then wash off. I use a garden "killer spray" (10 litre pump up cannister for weed killer) filled with hot soapy water. I then rinse with a hose. I usually run the engine before the final hose down and I avoid the distributor cap and alternator and airflow meter.
      To protect the metal again, I have used a spray wax from the VW/Audi dealer but it's expensive and collects dirt again very quickly.
      Steve
      Steve
      Scottish Cecotto
        I just did this with my engine/bay ... I used the good old car wash(the do it yourseld type).First and most importantly I let my engine cool to the blue. Then I sprayed tire cleaner on the engine the whole two minutes .. (as alowed), I let it penitrate for a while since my engine is cool. Then I just spray it off but I go to this place that has hot presure water so it doesn't leave any waterspots. Then I wait another 10 minutes then start her up.
        Finnally Powered by my ///M3
        1990 E30 M3
        1973 M2
          Cool, thanks guy's. Just wanted to be safe.
          I had a problem years ago on an E30 325i caused by doing this (water got in some electrical connection low down on the engine)
          Mags
          '90 M3
          '02 Suzuki SV650S
