fuel reservoir before pump
Originally posted by hardtailer View Postdo a search for 'pulse dampener', it can be left out.
you asked for #20 in your first post. That seems to be a piece of hose nowadays (Uwe, your right it's not the usually mentioned damper, although it'S referred to as another damper in this diagram http://bmwfans.info/parts/catalog/E3...ply/fuel_pump/. It probably dampens the pulses from the lift pump inside the fuel tank ) so that should answer your question, i.e. it can be left out.
#14 is the damper and can be definately be left out.Last edited by hardtailer; 03-07-2010, 11:26 PM.
Originally posted by hardtailer View Postyou asked for #20 in your first post. That seems to be a piece of hose nowadays (Uwe, your right it's not the usually mentioned damper, although it'S referred to as another damper in this diagram http://bmwfans.info/parts/catalog/E3...ply/fuel_pump/. It probably dampens the pulses from the lift pump inside the fuel tank ) so that should answer your question, i.e. it can be left out.
OK. Thanks :gotcha:
