Plese help ABS Question.
  • Plese help ABS Question.
    Hi all,
    My car is 90 and this ABS issue drives me crazy! ! !
    Ok hear is the symptom.
    1. When I am driving and apply light brakes to stop the car the ABS start working hrrrrrrrr and pedal is hard?. When the car is full on stop the pedal goes soft as it should. I changed the brake booster with the pump and still the same.
    2. When I start the car the ABS light is off when I start cruising after 10 comes ON. ? Some times is on from start.
    Possible issue???
    ABS Sensors ?
    ABS Unit ?
    ABS Relay, if yes which one ?
    Thank you guys.
    Anri
    E30M3
    E28M5
    E24M6
    E24M6
    E24M6
    E24M6
    E31840Ci/S62.
    Originally posted by First E30 M3 View Post
    Hi all,
    Possible issue???
    ABS Sensors ?
    ABS Unit ?
    Thank you guys.
    Anri
    so you listed all the options already. Now go and check them.
      ABS sensors...check them
      '88 Sep 03,87 Zinno/Natur 2.5L--the queen
      '90 White/Natur 2.3L---the weekend
      '14 GT-R Red/Black ohhh..yeah!!!
      '09 E82 135i Crimson Red/ Black w/M-Tech goodies--sold
      '94 11/93 AW III 525i M50/S50 cams/5 speed swap--sold
      '11 Nissan Rogue White/Gray
      '89 Wrangler 4.2L 4x4 5 speed
      '66 VW Beetle
        I don't understand your description but, if you are getting a pulsation from the pedal when you hit the brake pedal, then your ABS sensors and ABS pump might be ok.
        If a wheel speed sensor and or the ABS ECU is bad, the ABS pump is deactivated. Hence I'm not getting the "Rrrr" bit.
        It is possible that you have a smallish grounding of one of the sensor harnesses, so check for a damaged harness sheath under the rear seat at each side. Sometimes the rear seat squab metal braces can abrade the harness.
        The ABS relay is incorporated in the pump chassis for late M3s. Pop the plastic cover on the pump and look for any scorch marks on the top of the pump.
          Thanks you guys.
          Uwe I did NOT change anything yet.
          That was just my guess what could be.
          I try this morning to Disconnect the ABS ECU for about 5 mins and plug it back and the system worked perfect for about 10mins and then got bad again.
          OK I will check the ABS sensors. Open and clean them up from dust or possible rust ? Will that be ok or changed them ?
          Mark, the "hrrrrrr" is the pulsing pedal at light braking. Sorry for my language.
          Anri
          E30M3
          E28M5
          E24M6
          E24M6
          E24M6
          E24M6
          E31840Ci/S62.
            Had this happen to me on two different cars. Each one had a bad ABS sensor. Disconnect them and measure resistance across the pins. It should be somewhere around 900 to 1K Ohms.
            Ron ///Man
            • '89 M3 M3T / ITR Club Racer
            • '94 Spec E36 - Eh....
            • '09 M3 - Tarmac Terrorist
            • '07 530 Xi - Highway Star
              Seems like I will start diagnose the system first with the simple things.
              Will start checking the Sensors for the correct Ohms and continue.
              Anri
              E30M3
              E28M5
              E24M6
              E24M6
              E24M6
              E24M6
              E31840Ci/S62.
                Anri
                If you have been using metallic content brake pads the trigger wheels and sensor points could have metal particles contaminating the system.
                  Even if all abs sensors pass the resistance test, you may still have a bad one. The ONLY way to really test the sensor is to set a multimeter to the alternating voltage setting, rotate the wheel by hand and then look for large differences in value.
                  A good abs sensor should easily reach 3v output turning wheel by hand. A bad one will be much less (e.g. Less than 1v, often an order of magnitude less).
                    Thanks you guys.
                    Over the weekend will start diagnose the system.
                    E30M3
                    E28M5
                    E24M6
                    E24M6
                    E24M6
                    E24M6
                    E31840Ci/S62.
                      i doubt its a sensor issue.
                        Have you changed your bearings lately??
                        My experience: I had a mechanic swap my units for the cheaper HD e28 M5 units and they left one of the rings of the M5 on it, sending me into an intersection... Rather than risk my ///M I've disconnected the ABS computer 3.5 yrs. ago and still have it in a box. But I had similar symptoms to what you're describing and it was the sensors, so I replaced the bearings, sensor rings, sensors... still don't trust the ABS so it's still in a box.
