Do they share the same front structure? From realoem, they have different part no although they look 99% identical.
e30 m3 and 325ix
sorry..i think i need to elaborate more... Front structure is the front section (front suspension tower etc).
I have a converted 2dr 325ix to a complete e30 m3 replica. Just bought the whole m3 undercarriage (suspensions, struts, fr and rr axles, etc) and would this be a simple bolt on to replace the 4wd system?
No, I believe your 325iX front strut towers sit at a different angle than E30 M3/Non-iX E30's front strut towers. If memory is correct, this was done to help eliminate the "negative" camber aspect on the front suspension to allow for less front halfshaft wear.
I could be entirely wrong, but I don't think it is a "bolt on" affair.
Good luck,
ChrisLast edited by UNHCLL; 04-15-2010, 03:41 AM.Chris L.
Originally posted by Bennetts22 View Postway different for sure will not work
A bit background about the car,
It was used for rally purpose back in the 90s and bought by an individual who converted to RHD and change the look to e30 m3 using original parts. The motor is m20 2.7L Racing Dynamics. It was in my hand since almost 2 years ago.
Chris
The issue is that the iX strut towers are different. My understanding is that you can bolt the suspension up, but you will have essentially no caster, instead of the normal E30 huge caster setting.
The car won't drive properly like that.
IMHO, you're better off finding another shell for this conversion.2011 BMW M3 Alpinweiß
2006 GMC Sierra 2500HD
1990 325is Brilliantrot
1989 M3 Alpinweiß
Hers: 1996 Porsche 911 Turbo
Hers: 1989 325iX Zinnoberrot
