Is there anything under the dash that would be wise to replace during a dash replacement? Thanks.
Parts to Replace
You might want to take a look at the heater core and pipes while you are there. Although you can change these even with the dash in place but the center console has to be removed. Also maybe change out the all the little light bulbs.
If ever things else works now then you should be fine.
Folks, while we are here, can anyone tell me if there is a convenient pass-through in the firewall behind the dash/foot-well area. I want to install a pressure gauges and pass the wiring down to the steering column.
Originally posted by noro View PostFolks, while we are here, can anyone tell me if there is a convenient pass-through in the firewall behind the dash/foot-well area. I want to install a pressure gauges and pass the wiring down to the steering column.
That's perfect Joe!
To the OP. If you are at all contemplating replacing dash bulbs with LEDs, don't bother.
