I've searched all over and haven't found any threads with my particular problem. I hope someone hear can help.
I installed the HID kit from DDM a few months ago, it worked fine for some time. Periodically my drivers side light would go out, but a simple recycling of the lights or if need be a disconnect/reconnect got it working again.
The other night the light goes out again and neither of the two fixes got it working again. I touched the ballast in question and it was SUPER hot. When I got home I swapped out the ballasts and the light still did not work. I reconnected the ballast back over to the passenger side now that doesn't work either.
So now I have no low beams at all. I've checked the fuses, none are blown. My relay also clicks when I pull the switch so I don't think that's the issue. I reconnected a regular 9004 bulb and that doesn't work either. The high beams work fine. Please help
