Durability of aftermarket motor mounts
  • #31
    For those who have experienced failed stock mounts (S14 or 740i), I wonder if the failure was due to many years of service. I'm thinking if I replace the stock mounts every year or two (treat it as regular maintenance item), the mounts may not degrade much in performance and it is still cheaper than buying a grp N mount.
    • #32
      it will be nowhere near as good as Grp N mounts.
      • #33
        while on the subject, can someone give me the part # for the group N motor and transmission mount please
        thanks
        • #34
          Originally posted by JS154 View Post
          Gruppe N mounts are stupid expensive. And they will break just like a stock one too. But they are stupid expensive.
          I have not seen any evidence the BMW Motorsport Gr.N mounts break. They will eventually wear out but not break. There is a big difference in the potential damage it can cause ... The high initial price is offset by their longer life cycle. It is a well tested item over the course of +20 years of racing ...
          The only other valid option for track use are the Gr.A replica aluminum mounts Conrad is making. We had Gr.A magnesium mounts as well but decided to sell them.
          1986 BMW E30 M3 CF airbox & Alpha N
          2007 Audi RS4 sedan
          • #35
            thanks
            You have it in the pictures I posted a couple of days ago. The p/n is engraved on the cup:
            11811417407 N
            2007 Audi RS4 sedan
            • #36
              Lee,
              Your ireland thread was the first thing I thought of when I saw that pic of the failed AKG mount.
              Amazing they just "re-made" the same mistake / design flaw
              • #37
                If anybody here wants to make engine mounts, I would gladly collaborate and submit ideas.
                • #38
                  MMMM thanks, saw the photo but not the #'s, how about the transmission mount #
                  so group n vs conrad's
                  any clear choice
                  is one or the other easier on the frame?
                  thanks
                  • #39
                    Wow,,,, I am shocked at the failure mode of the AKG mount.
                    How the f*ck could they not expect that to fail.
                    Thats a horrible design.
                    So glad i didnt buy a set of those.
                    Still cant believe the AKG mount has so little meat into the mount.
                    Thats just designed to fail. Shame.
                    That was my initial thought, but then think of it this way....
                    I would rather have a sacrifical mount fail under impact stress like I mentioned, which I can swap out in 10 minutes in the paddock, versus having the ears on the tranny break off, or have the trans crossmember fail.
                    Kinda the same reason the two-piece driveshaft makes sense - in a similar situation, it;s just going to slide apart, instead of a single piece design putting all sorts of stresses on guibos, diff and diff mounts and subframe mounts etc...
                    all the stress has to go somewhere, best to sacrifice an easy to replace mount.
                    • #40
                      in an impact, even minor car to car - the Grp N mounts will break. I've seen it time and time again on other droivers cars that I refuse to spends the hundred$ of dollars when I can get a stiffer mount like AKG or Ireland for less.
                      Keep spares in the track bin. simple.
                      • #41
                        Well,,, sadly,,, I'm pretty sure AKG didnt have that design intent of the sacrificial motor mount in mind when they made them, I think it was just bad design...
                        However Eric,,, I think your statement has merit in that I would also rather replace a motor mount than a subframe at the track (or even periodically as a service item).
                        I got so incredibly sick of replacing motor mounts at the track, I just went solid.
                        I think the AKG could be the "next best" design to Grp N if they just had a deeper / better anchor into the delrin.
                        Then in theory it could still sacrifice fail if needed in an impact, but not tear in half under aggressive service which is what happened.
                        I bit the bullet og the Grp A replica arms,,, once again making both cars more similar by the day, nut by nut, bolt by bolt haha.
                        • #42
                          Jimmy hows the noice and vibration with the solid mounts?
                          I suppose you could run solid mounts, and notch the trans crossbrace so that part fails first under high load, instead of the trans ears.
                          That bracket would be easy-peasy to swap out.
                          • #43
                            Fairly horrific.
                            I have a pretty high tolerance for NVH, I used to drive a fully solid mounted GTO drag car and enjoyed it many years ago,,, but yeah, its about as bad as you would expect it to be with a buzzy 4 cylinder solidly bolted to a solid everything else car.
                            Shit is constantly vibrating off.
                            Loctite red and blue and Nylock nuts everywhere are my best friends.
                            Quite literally if I cannot get a nylock nut on something, its got loctite on it because otherwise, it will fall off.
                            However,,, i wouldn't change a thing (for a dedicated race car).
                            its so direct.
                            Transition throttle is so much fun.
                            I couldn't go back.
                            I enjoy the benefits much more than I am annoyed by the downsides.
                            • #44
                              ^ Jimmy is my effing hero. Probably the #1 E30 M3/S14 fan if there ever was one.
                              Jake
                              • #45
                                Jake
                                Yup....
                                The mere thought of a solid mounted S14 scares me. I once tried a solid shift lever (no rubber insert) and it about drove me crazy in a mile.
                                I would also worry about actual fatigue that would occur by all that vibration transfered directly to the chassis.
