Durability of aftermarket motor mounts
  • #46
    any other comments on the burtonpower.com mounts mentioned earlier in this post?
    thanks
    • #47
      the only thing is they are shorter than stock so my front sub-frame reinforcement makes up the height difference
      Jason
      • #48
        Fairly horrific.
        I have a pretty high tolerance for NVH, I used to drive a fully solid mounted GTO drag car and enjoyed it many years ago,,, but yeah, its about as bad as you would expect it to be with a buzzy 4 cylinder solidly bolted to a solid everything else car.
        Shit is constantly vibrating off.
        Loctite red and blue and Nylock nuts everywhere are my best friends.
        Quite literally if I cannot get a nylock nut on something, its got loctite on it because otherwise, it will fall off.
        This is why I opted for the Gr.N engine/transmission mounts. I have a dedicated track day car, not a proper race car (not yet anyway) so solid mounts imply problems in many other areas. Since installing these I have done 7 track days and +10.000Km so I think it is safe to say they work for my purpose better than any aftermarket option.
        1986 BMW E30 M3 CF airbox & Alpha N
        2007 Audi RS4 sedan
        • #49
          Originally posted by Jake View Post
          ^ Jimmy is my effing hero. Probably the #1 E30 M3/S14 fan if there ever was one.
          Jake
          Haha Jake,,, I am humbled,,, thats high praise coming from a man who has (at minimum) an entire E30 M3 in parts "in" his house and invents tools to better service his S14.
          Cheers
          jimmy
          • #50
            any photo of OEM broken group n mounts?
            i want to see what the inside looks like
            so we might learn from them
            also what side usually fails in normal fails on motor mounts, header side?
            thanks
            • #51
              thanks
              For me it was usually the tension side (drivers) that failed more often.
              Just pulled them in half (tears the top off).
              • #52
                I'm planning to use the ice hockey puck/pucks, sandwiched by aluminium plates, threaded so i can tighten them up. I have yet to make them, but this is the idea so far.
                Toby
                E30 87 - S14 Turbo
                E34 90 - M5
                New BMW & Mini OEM parts - www.bmminiparts.com
                • #53
                  Don't use aluminium plates. I would recommend against this solution with your engine setup, it's not going to last very long.
                  • #54
                    i know a few rallye drivers here in germany who are using these ones here without problems....but the cars are only for racing
                    Markus
                    • #55
                      Very interesting design that makes sense. Even if the bushing failed, the assembly would not allow the motor to move forward. Great idea.
                      • #56
                        if the little silent block rips apart, whats holding it together? all of these blocks are designed for compression, not tension
                        • #57
                          UweM3
                          doesnt the part in the center take compression and tension as it is screwed into both the upper and lower mount caps? and the center part is bonded together.
                          i have recently heard the group n mounts are similar with plates bonded to the material not captures inside or interlocked.
                          would be nice to see a broken group n to get a better idea of its construction
                          • #58
                            Someone with a genuine Grp N mount needs to "take one for the team", cut it apart, and post its inner secrets here.
                            Not me of course.....someone "else".........:idea:
                            • #59
                              i like the looks of the ones marcus posted here
                              anyone know a source
                              thanks
                              • #60
                                well, not me this time. I only cut cylinder heads, blocks and 215bhp exhaust valves apart (which are NOT sodium filled BTW).
                                I am sure there is the odd old worn out Grp N mount lying on the shelf somewhere. Not much worth really.
