Rubber intake gasket help!
  • Rubber intake gasket help!
    Rough idle led me to change the tb gaskets. I purchased the Turner kit, sealed the throttle body side, put on the old rubber gaskets and noticed the two sides didn't quite match...
    Also found that the part numbers for each side also didn't match up:
    Right-
    gasket: 1 318 319
    tb: 1 310 024
    Left-
    gasket: 1 318 318
    tb: 1 310 023
    I've done quite a bit of searching and understand that some part numbers have changed, however, this just doesn't seem to make any sense. Do you think the previous owner could have changed something? The car was running fine with this setup before, and I can't recall if they were positioned like this when I took everything out, but the looks of it just irk me.
    Help??
    well, looks like you have a 46mm throttle gasket and a 48mm throttle gasket.
    read here http://www.e30m3project.com/e30m3per...kets/index.htm
      do you think it would be alright to continue running the car like that?
        you could fit 2 "large" gaskets and port match the throttle bodies at least.
        but I would not run a small and a large
          All the new gaskets are 319's. If you find original 318's then it's new old stock. My guess is it's not that big of a deal unless you NEED the extra airflow provided by the 319. On a stock car, I would leave it, maybe hone it out and reseal the intake. Those gaskets are expensive.
            Cut down the 318 gasket so it fits more like the 319? I need to get the car back together fairly quickly so that's an appealing option.
              +1. In fact, I thought you can't get the large ones any more. I agree, use one or the other but don't mix them.
              zhpregistry.net
                You can't get the small ones anymore.
                  This is what I would do if the gasket is still good. Just open it up a bit. Like I said, a new one is expensive.
                    This is correct. Even back when I did my motor you couldn't get the smaller ones anymore. I did, however, opt to alteast match the gaskets so I bought two new ones.
                      I have had talked with some well respected S14 motor builders regarding these matters and I am informed that the larger gaskets, while not a true fit to the ports, show no adverse results resulting in lower dyno readings. While an odd small and large mix is not ideal you would be fine with this arrangement. (The new gaskets available now are all the 48mm larger ones.)
                      I do notice some dry cracking on your gaskets so the question is, why not replace them since your this far in? These gaskets are designed to serve a couple of functions. One is to seal the intake run and the other is to aid in vibration damping due to the high vibrations these motors produce. I suspect the vibration damping ability of the old rubber is past its service life cycle. I am a firm beliver in doing it tight the first time.
                      Is it common to only install the Turner paper gaskets with the old rubber?
                        replace the rubber gaskets too. the turner kit helps the new ones stay sealed, but you are going to have to do the job soon again if you don't replace the rubber gaskets now...
                          I have the same problem with the new 319 rubber gaskets. Although there is not a problem with the larger gaskets: Do you think it's a good idea to port the final part of the intake to match the 319's gaskets?
                          Thanks.
                            I tried this paper gasket to the TB side.
                            What do you think about?
                            Thanks.
