changing diff oil?
  • changing diff oil?
    Exactly what size allen wrench do I need to change the oil? thankyou
    17mm
    -Han
      Originally posted by H a n
      17mm
      Come on Han, DIFF fluid, 10mm. 17mm on trans.
      It will STINK, replace it with good Synth fluid like Redline or Amsoil, and make sure it is good for LSD.
      Do not click
      At least it's German
        oops! You're right Mike, it's 10mm....
        I read diff and thought tranny.
        Magnus, I need a "smack yourself in the head" smiley.
        -Han
          Isn't there a rule that you make sure you can break loose both bolts so that you don't have an empty diff with a stuck fill bolt.
          Tony
            yup, you should remove the fill plug first, then the drain plug.
            the reason is that if you drain the fluid, and then can't remove the fill plug, you're stuck with an empty diff (won't be able to drive).
            removing the fill plug also makes it drain quicker/smoother.
            -Han
              Club Me 7
                The diff dosen't have a drain plug. Just a fill plug. You need to use a suction device to remove the old fluid.
                  Actually it does have two plugs. Go check it right now.
                  Nice to see you on here Ped, I drove by you a few weeks ago on Murray while I was driving my corolla. My friend was in the car with me and he loved your car!!
                    There are 2 plugs.....
                    Do not click
