tire size for 16"?
  • tire size for 16"?
    I want to put 16x7.5 wheels on my car but I am having some difficulty figuring out what tire size I need. Tire Rack's site says the size for the optional 16" wheel is 225/45zr16. I called them and the person I spoke with said no, I should use a 215/45zr16.
    The particular tire I am interested in is a 225/50zr16.
    My question is: those who have had experience with 16" wheels, will a 225 tire rub? tires are not my strong suit, and I'm not sure if the middle number affects how well it will fit the rim. Also, would the tire size I want cause problems?(225/50zr16, closest size for the brand I want) Any exp/comments/help with this size wheel and tires would be appreciated. Thanks in advance.
    Ben
    90 brillianrot red M3
    -chipped
    91 325I sport
    -chipped
    -triflow exhaust
    The proper size for a 16" wheel is 225/45/16
      would that rub at all? Would a spacer be required? My tire/wheel knowledge is somewhat limited
      -chipped
      91 325I sport
      -chipped
      -triflow exhaust
        It shouldn't as long as the offset it right. Which should be ET 27
          I have 16 x 7.5 rims and are running 225/45 x 16. No rubbing.
          Cheers
          Dave
            225/45/16 was the stock size tire of the Sport Evo, Evo 2 and Cecotto.
            -Han
              9.2" wide,
              4.13" sidewall ht,
              24.2" total dia.
              76.0" rolling circumfrence.
              833.7 revs/mile.
              225 50 16:
              8.7" wide
              4.35" sidewall height.
              24.7" total diameter.
              77.5" rolling circ.
              817.5 res/mile.
              205 55 15 stock:
              8.3"
              4.5"
              24.3"
              76.3"
              830.4 revs/mile
              So you can see that the guys are correct as the EVO sizes throw your speedo accuracy off the least..
              btw, I bought a set of 16x8 revolution RFX that had 225 50 16 tires mounted and there is no rubbing.
              m.
                thanks for the info. this has been very helpful, I'm glad I decided to post. Now I just need to find some wheels I actually like, which is proving to be more difficult than I thought.
                Ben
                -chipped
                91 325I sport
                -chipped
                -triflow exhaust
                  How about 245-45-16 rear on 16x8.5 with et25? Will this fit?
                  Robert
                    I was using 245/45 a few months back and I was getting a very little rub.
                      225*45 still fits on an 8.5 inch wheel, I would use that size. The rolling circumference of a 245*45 is quite a bit different and will affect performance.
                      I used to run 225*45 on a 9inch wide wheel - looked a little stretched but not too bad at all.
                      1988 Evo II
                      2006 Z4 3.0Si Sport Coupe
                        I'm picking up a set of 16x8.5 soon. It's an odd size that isn't discussed all that much in the forums.
                        The debate is whether to run 225/45/16 or 245/45/16.
                        225 doesn't rub from what I've read, 245 has a chance of rubbing. I wish I could mount each size and have a go myself... but I can't.
                        (Maybe I could run 225 in front and 245 in the rear but I've read that understeer becomes very pronounced w/ staggered sizes)
                        I'm not looking for the super euro stretch look. I don't want to fight a rubbing battle either. Does anyone run a similar setup w/ comments on street use? Maybe even pics
                          Originally posted by Mmark
                          225 45 16:
                          9.2" wide,
                          4.13" sidewall ht,
                          24.2" total dia.
                          833.7 revs/mile.
                          225 50 16:
                          8.7" wide
                          77.5" rolling circ.
                          817.5 res/mile.
                          205 55 15 stock:
                          8.3"
                          4.5"
                          24.3"
                          76.3"
                          830.4 revs/mile
                          m.
                          How come your two 225 tyres are a different width? I thought 225 was the width?
                          I have 225/45/16 on 8" fronts and 9" rears. Had no rubbing with Goodyears and Falkens but I have some cheapo tyres on at the moment which do rub on the inner arch at full lock.
                            Re: tire size for 16"?
                            Ben
                            225 50 16 WILL rub.
                            Front suspension:
                            It rubs at 3/4 to full lock at the front and rubs heavily at the rear to abrade a portion of the wheelwell liner and paint off the unibody.
                            Rear suspension:
                            It will catch the sharp lip of the wheelwell on suspension compression and 2 or more passengers.
                            And this is on a car that has stock springs with some Bilstein sport jacking.
                            If you are looking at Gforce sports, I can 100% guarantee this occurence On a stock suspension. A lowered car will be worse.
                              My car is setup with gc coilovers and lowered. I ran the falken azenzis size 215/45/16 for autox and never had any rubbing. Now I have some bridgestone so3 225/50/16s on the car and they rub a good bit in the front. In fact, the po damaged both front fenders with them. However, now with the camber adjusted I only have inner rub.
                              I am thinking about mounting up a set of hoosiers 245/45/16 and working on fitment. They certainly would be sweet if I could get them to fit.
                              Cheers,
                              88M3 henna
                              73T100C
                              97 540\6-Gone
                              2008 MINI Clubman S
