Building a Gr.A Replica
  • Building a Gr.A Replica
    Hi guys!
    well, at last, i´ve nearly finished this 5 year project!
    Project started since i crashed, and front part was a mess. I ended up buying a e30 front from the junkyard, and tack welded to the M3 body. It ended unnoticeable.
    The engine belonged to a rally car owned by Jose Maria Ponce in Spain, he was champion lots of times, and a guy here in peru bought that car, but sadly, he crashed and now rests in peace. I managed to get that engine, and of course, rebuild it with the same motorsport parts.
    All the electronics was done by myself, pretty tough job, had to make a new fuse box, and install the Haltech ecu. The cage job was done by an expert in this area, with loads of M3 pics to replicate the cage, but still meeting the peruvian racing rules. He also did every mod, like welding the weak spots of the chassis, suspension, brake mods, seat supports, etc, etc.
    Front brakes are from lee @ massive. 6 Pot willwood calipers, very good stuff, rear brakes are OEM. Wheels were made in Spain, so this brakes could fit, the company is called Braid, and they make wheels for rally and circuit scenarios.
    Chasis Welded
    Doing The Body Work
    At The Cage Guy
    Reinforcing The Chassis
    Suspension Installed
    Aluminium Steering Coupler (was anodized in red then...)
    Seat Supports
    Rear Strut´s Reinforced
    Rear Diff Bolted To The Cage
    Base Paint
    Painter´s Stuff
    Engine Bay Ready
    Interior Ready
    Installing Aerocatch Pins!
    Excellent Product
    Rear Already Polished
    Front Ready (The Red Thing Is A Sticker ) Brake cooling ducts!
    Engine Porn (The Real Oil Pan Was Totaled, So I Put an OEM One)
    I Should Have Taken a Pic of the intake of this cylinder head, it was a LOT bigger compared with the standard one.
    Check out the blue crankshaft
    90% Ready
    Lumpy Camshaft
    Trigger Wheel for Haltech ECU
    Mono wiper conversion, for those who want to make one, take a look at that design, it also allows to put a battery kill switch like the DTM cars on the drivers side linkage.
    Painting the stripes.. at first, i made the stripes from vinyl, but the sun messed up the work, and i decided to go for paint.. like the real racing car.
    Nice part! check out the Oil Catch.. i managed to buy the e28 reservoir tank, and installed the fittings... also made the outlet from the valve cover to aeroquip style, it was hard to get all parts, but i really wanted to copy the original dtm car.
    VAC Fuel pressure regulator
    One Belt pulley, and big alternator pullet, dtm style
    Interior
    Fuse Box + Haltech
    Momo 350mm Steering Wheel + Lifeline Quick Removal device
    Tilton Rear Diff Cooler pump + 2 Bosch 044 fuel pumps (feeded by the walbro lph255 intank)
    Daddy and Son
    Lexan windows at the sides
    Thats all i got! i will try to take pics from underneath, car if also beautiful from there!
    hope you guys can share comments!
    see ya
      Very nice!
        Esta increible!
        2.0L = TC2000 o 2.3L = Fuerza libre?
        Power?
        Por cierto, ponle un Mishimoto...no seas palomilla con el nacional o tinas nacionales! hahaha
          Very nice build with attention to detail...well done
          "But most of all...
            Beautiful build, can't wait to see a video of the car in action.
              What prompted the change from an X across the driver door to the NASCAR style bars?
              Chris L.
                Originally posted by diegom6 View Post
                Esta increible!
                Power?
                Fuerza libre!!!
                Ya llega el mishimoto!!este es pa probarlo nomas!!
                  Well, that is a must here for racing circuit, i first made it x , and then the rules changed, you must be 40 cms from the center of the seat to the bar, this made me clean the doors, and remove the glass and trim!! I wanted to keep those, to be similar to the original car, but, what can i do??
                  Thanks for watching!
                    So sick! Congrats on completing the project :buttrock
                      Ahora solo falta esto....:wookie:
                        I really like the dash support.
                        Jake
                          alucina que he conseguido el tablero, pero cuesta carito...
                          me parece por las huevas! jajaja, los relojes son lo mismo al final! que es eso del timón ah?
                            Where did you find the stacks. =) ^ (I have a feeling this has been already asked)
                              Love your attention to detail on this build!
