Has anyone else experienced a failure of these lines? I've been working a a big collection of e30's (10 w/1 M3), the owner swapped out all of the factory lines with Goodridge, 60 lines in all, so far 4 of the lines have failed, all the same way; the threads at the chassis end have corroded off and separated leaving the threads still attached to the hard line. I suspect it's because the hard line is steel and the Goodridge fitting is aluminum, they have that dissimilar metal corrosion look to them. He does run the cars in the winter, but none of the failed lines was more than 2 years old.
Goodridge SS line failures
I just installed a set of these 2 weeks ago. I've run a set on my Datsun for at least 5 if not 6 years and haven't had an issue. I think the set that I just installed on the M3 says that its DOT approved.
Will'69 Datsun 2000 Roadster vintage race car (Street driven on a regular basis :taz
'88 M3
Hi,
My Goodridge set is all stainless fittings with no problems. I have seen a few sets on other makes also with stainless fittings, are you sure they are genuine and not a copy.
Dave.
I'm sure they're genuine, they came from Bavauto, and he bought 60 lines. As for the material, the fittings may be stainless, but they look like aluminum, seem very light, and the thread corrosion is baffling if they are. They're very soft and non magnetic, but that doesn't rule out stainless either I guess.
He runs only high end Dot 4 and has decided to swap them all back to new stock lines now.
He was in contact with Goodridge today and they want some photos of the failed lines, so they're at least a little concerned about it. I'll keep you posted on developments.
Strange.
I ordered a set of "DOT" stainless braided brake hoses a few years ago, I think from Bav Auto but not sure. Anyway, they showed up with aluminum fittings. I realize they could more than take the pressure....but I dunno I just feel brake fittings should be steel.
So I returned the "DOT" hoses and assembled my own with stainless steel fittings. No problems yet.
Originally posted by Jake View PostI have a vague memory of this somewhere... failing aluminum fittings on brake lines. Hmm... Need to do some digging.
Jake
I chose a different manufacturer as a result.
When It comes to brakes, even a bad rumor will influence me.
Originally posted by Todd black 88 View PostMy goodridge lines are dot approved, stainless steel fittings, braided stainless lines with a clear PVC (or some type of vinyl coating) covering.
Mine were bought from turner years back iirc.
Originally posted by noro View PostNot to nitpick here but this is actually essential, DOT does not approve or disapprove anything, it sets standards to which manufacturers can claim they comply. So nobody from DOT has tested those lines.
Originally posted by ZM Blue Devil View Postthis is correct, thats what differentiate DOT approved and tagged. When it is tagged it means each line is tested on a machine and a number is printed on it. If it does fail it can be traced back to the manufacturer. These are the lines which are of better quality for obvious reasons.
For example, as mentioned above the "DOT" lines I bought had aluminum fittings. For brake parts I would much rather have steel.
The key is just making sure the parts are assembled properly, are of the correct length, and are installed correctly.
