Front Wheel Bearings
  • Front Wheel Bearings
    Hello all,
    I have been contacted by my local BMW dealer here in the UK who are looking for a pair of front wheel bearings for a late E30 M3 they are restoring. Unfortunately I can't help with new ones and BMW do not have a delivery date. The restoration is being held up because of this.
    Anyone know anywhere we can get hold of 2 brand new front wheel bearings?
    Regards,
    Paul.
    E30 M3 Sport Evolution Black
    E30 M3 Sport Evolution Red
    E30 M3 Evo II Red
    E30 M3 Evo II Blue
    E30 M3 195hp Black
    E30 318 is White
    E30 318 is Red
    I assume they know about just using an E28 bearing and swapping the ABS rings?
    Those are a dime a dozen...
    Cant imagine they cant find a pair of those.
      Bingo... just because it's not listed in TIS/ETK doesn't mean there isn't a solution.
      http://s14.net/forums/showthread.php...ht=e28+bearing
      Chris L.
        This place says they have them
        http://www.ultimategarage.com/shop/p...roducts_id=998
        As an alternative (which will probably be cheaper) you can use an E28 front wheel bearing but you will have to swap out the ABS rings.
        http://www.s14.net/forums/showthread.php?t=21991
        If you happen to need new rings this place has those as well ($$)
        http://www.ultimategarage.com/shop/p...roducts_id=388
          Paul, give Kirby at C3BMW a call they usually keep them in stock.
          Also GSF keep the E28 ones which like others have said need the ABS rings swapping over. My advice would be to go for their best quality items.
            Originally posted by ShepsEVO3 View Post
            Hello all,
            Regards,
            Paul.
            Concur w/ Jimmy and Chris - use the E28 bearing and swap the rings over, just make sure the ring is placed at the right depth.
              Agreed, but not only placed at the right depth but also that the ABS rings are clean
              (glass beading is the best thing here) of rust, grunge etc, and that you use some green sleeve retainer to insure they stay put.
              Ron ///Man
              • '89 M3 M3T / ITR Club Racer
              • '94 Spec E36 - Eh....
              • '09 M3 - Tarmac Terrorist
              • '07 530 Xi - Highway Star
                This is the two cheapest places I have found.
                http://www.autohausaz.com/search/pro...er=31211468753
                http://www.turnermotorsport.com/p-37...-assembly.aspx
