Hi all, well I am getting very close to finally getting this car back together, but am still puzzled about a few things the PO may, or may not have done when stripping the car. I am getting a bit frustrated at some of the stuff he did, but at I am getting closer!
I am trying to figure out the wiring to the 2 thermostat sensors.
Now, I searched the forum and found that the “plug” type connector (first picture below) breaking is a common issue, and that what has happened to mine. I ordered the plug and wires to fix that one, so I think I have it covered.
I also found this thread: http://www.s14.net/forums/showthread.php?18904-Thermostat-temperature-switch-and-wiring&s=
But, I am not sure about the other 2 pronged sensor on the thermostat.
This next picture is of the plug that I think should go to the 2 pronged sensor on the thermostat.
However, I also need an identical connection to my a/c dryer.
I looked at my iX and the connection to the dryer below, uses a plug identical to the one in the picture above. I can only find one of these connectors in the m3.
So, I guess the question is: how do I tell if this goes to the a/c dryer, or the sensor on the thermostat?
Any idea where I would find the other one?
Also, I assume that the wiring from the condenser fan goes to the connection over by the left head light. Seems like a long wire to go that far, so I just want to make sure this plug DOES NOT go to the sensor on the thermostat, or somewhere else I can’t find a connection for?
Again, I apologize for the long thread, and apprecaite all the help.
Don
Don
