Group N Springs
  • Group N Springs
    I just installed my Group N springs today.
    Notice the difference between Group N and Original.
    http://home.tiscali.nl/bmwwe30m3.nl/...0N%20Front.jpg
    http://home.tiscali.nl/bmwwe30m3.nl/...20N%20Rear.jpg
    Rear fits O.K. , no problems there.
    At the front the springs are too short :grr: .
    When car is jacked up, the springs came loose.
    There was a thread from Mick recently, who had the same problem. Some guys said it isn`t such a big problem.
    I`m not sure about that !
    What do you think ?
    I am confused. I was under the impression that the Gruppe N springs fit the rear, but the fronts are for coil-overs. I know there are many different versions of the springs, so maybe you have another kind. Mick has j-stocks, which are short. I also have them in the Henna. We use zip ties to hold them in place.
      My H&R Race are "loose" when un compressed....rear and fronts...
      No big deal at all....im even going to cut a coil from teh front of the race's once i see that my simmons fit
        My springs come loose too... you just have to make sure they don't shift positions relative to the spring hats before you lower the car back down.
        Do not buy from "Low Level"!
          There are two versions of the Grp N set up. One uses a coilover design up front with adjustable height, and the other is a standard set up meant to work with standard struts.
          HTH,
          Jake Larsen
            Thanks for the replies guys.
