Kids. I have the brake lining light on in my cluster. I replaced both sensors (driver's front and passenger's rear) and still have the lining light on. The light was on when I purchased the vehicle. I need to turn it off to pass light inspection. Any help is appreciated.
Brake Lining Light on... Help
Originally posted by BBS16 View PostHow about the fluid level sensor?--------------------------------------
What about the brake light switch? I remember on my E36, a faulty brake light switch threw a brake circuit error on the OBC. Is there an E30 equivalent of break light switch? Would a faulty one throw a brake lining light on the dash? It's necessary to mention that the brake lining light is on as soon as I turn the car on without any application of brake. The brake light LED is on on the OBC but will disappear as soon as I step on the brake. The brake lining light in the dash, however, remains illuminated.--------------------------------------
IMHO these things arent necessary if you maintain your car well. Do away with them, cut the wires to the sensors at the front and back and join them together with a connector. Problem solved permanently !!!
"But most of all...... I like the way you move......"
Well a broken wire somewhere in the harness will cause the light to come on. You'll need to check continuity through out the front and back circuits.
In my case the problem was a broken solder joint behind the gauge cluster. Unfortunately you may have to remove the gauge cluster to properly diagnose. Check the connectors and clean them under the wheel wells first!There'll be Spandex jackets one for everyone ...
89 m3 "Ms. Bavaria"..... Cinnabar w/ Black Guts, Evo 2 cam, Miller War Chip, CF Intake, What's a cat?
12 Avalanche "OJ" ..... Black on Black, Loaded, and Runs
08 335i "Vanessa" ..... Black with Buckskin guts
08 Jetta 2.0 Turbo "Joan Jetta"..... Red with Tan Guts
Originally posted by OnrailsM3 View PostCut the wires back, twist them together and abandon the system. If not, check at the rear trailing arm bushing. Right there is a spot these wires break opening the circuit and kicking the light on..
I have a working level sensor if you want to try it out. I would check continuity of the connections under the back seat and up front to make sure that the sensors are getting to the connections and then work it back to the cluster. I have had the same problem in many cars and it is usually the sensors which you have already changed.
Cheers,
JimLivin the Dream
