So I took my head in to a local machine shop and they said it is warped six-thousandths down the center. The exhaust valves have leaks as well. Who should I send it in to to get fixed? Also I was thinking of having some head work done as well while it is off. I am planning on staying with a 2.3 but the future mods include the whole a/n, c/f airbox and throttle body setup. With this in mind what should I have done to the head? I was thinking of sending it in and having what ADA///M had done to his head but Pete McHenry told me he isn't taking in any new work until September. What would you guys recommend me to do? I would also like to add that this is a street car which is used for everyday driving. Almost 100k on the clock.
Head is off
Have the head skimmed, and ported to match the EVOIII intake blocks. This will raise your compression a little, so if cams are in order you will want to go ahead and do measurements while it is off. Valve seals, seats also. I had my head ported, polished, and 5 angle seats performed locally for $500.
